kenwood cooker
  • #41471
    hdltd
    Hi can anyone help me
    I have a Kenwood CK410 dual fuel range cooler and the lower fan oven element has blown the problem is HOW DO YOU REMOVE IT ???
    has anyone done it
    Please help
    John
    #270296
    knobs
    Re: kenwood cooker
    Done few of these,the first one had me going a bit !!
    pull the oven out ,take the back off ,you should find 3 screws that should be holding the floor of the oven in place,there should be the same at the front as well.it can be a bit of a job to pull out the floor,i found if i use long nose pliers at the back right hand side of the floor and pull up,it usually works.
    i think its the same cooker as a CDA, once the floor is out its easy to fit the new element.
    #270297
    Lawrence
    Re: kenwood cooker
    Ditto
    Did one last week ,but the floor pan was a pig to get out lots of wiggling and levering and then it came out
    Lawrence
