Fitted new board today for a no heat fault. After fitting display comes up e3. Put old board back in and it works fine apart from the original fault. No instructions came with board so I’m assuming its pre- programmed. Anyone had similar problems
if it the old model they have brass toc,s at rear , if newer model they have a heat/pressure micro switch built into sump hose … both accessed from rear lower panel..
Andy, I think you are new to UKW and probably didn’t realise that technical questions should always be posted in the Trade Technical forum not in General Trade. Sorry I can’t answer your question by the way other than suggesting Kenwood dishwashers should be put in the nearest skip. 😉
Martin wrote:Andy, I think you are new to UKW and probably didn’t realise that technical questions should always be posted in the Trade Technical forum not in General Trade. Sorry I can’t answer your question by the way other than suggesting Kenwood dishwashers should be put in the nearest skip. 😉
I am new mate. And yes I’ve suggested the scrap yard
