Kenwood dishwasher KID60S10
  • #81454
    sce
    Help/suggestions please on this pile of built in junk.
    Problem is the conveyor plastic tube that goes from the motor to the top wash basket has a branch pipe that goes from a moulded nozzle right to the top of the machine to a nozzle which sprays h2o over the top of the cups. In other words this d/w is very similar to your bog standard Indesit pile of nonsense this Kenwood is based on. Problem, this branch pipe conveyor end keeps falling off = leak = Eo4 flood code.History: apparently this has happened twice before so bod said, but only when of course I get to his house,the last time it was a year ago- found pipe held on with a knackered bodged clip and 2 pull ties! I glue this pipe to the nozzle and fitted a spring clip and tested the machine a whole cycle and the machine worked fine, now i fear it has now fallen off again. I know that this pipe is not blocked up BUT it may be that there is a blockage, say going to the bottom wash blade which increases the pressure elsewhere hence the disaster. Anyone ever had this problem, do you think I am on the right tracks? Anyone got any other ideas please? Going back tomorrow!!!
    #416667
    Panther
    Re: Kenwood dishwasher KID60S10
    Hi use a 16mm jubilee clip an some debor glue I’ve done this loads of times in the past an never had 1 come back off good luck
    #416668
    sce
    Thanks, sorry for late reply…..that`s what I did and your right so far hasn`t fallen off yet. Thanks
