Kenwood dual fuel double oven, Model CK 404 FS
Issue concerns the main oven. I believe there are 2 elements. The top element (grill) heats up ok and I presume should not work with fan assisted.
When fan assisted the `main` oven should heat up using (I think) just the bottom element. This does not happen, the fan runs but no heat.
All other parts of the cooker appear to be working ok.
In my unqualified diagnoses I suspect the heating element or maybe a switch connection.
Any guidance would be appreciated including if necessary how I replace the element as in` in situ` or do I have to access from the back of the cooker.
