Hi guys the small oven stat is broken ,do I have to do anything to the gas side to replace,acess not obvious as I cannot get the side panels off, not gas safe so dont want to be compromised. Cheers Johnnyboy
my rule is that if you have to disturb the top, DONT do it. Its not worth the potential consequenses. i do however change oven elements in dual fuel if i only need to remove back.
