Kenwood FF
  • #93562
    Stretchy79
    Hi guys.
    Got a Kenwood KSBSB15 fridge freezer and starting to have coldness issues.
    Started the odd beeping then continued onto lots of random beepings lasting about 10 seconds or so.
    Compressor seems to be operating ok but I have put it into super cool mode after the food was starting to defrost.
    Super cool is supposed to be -25 but it certainly doesn’t feel like it.
    Does anyone have manuals for this FF or advice please? Based in Leigh on sea, essex for any engineers that would need to visit.
    #454810
    Re: Kenwood FF
    first thing to try on all modern fridge freezers is a complete defrost. switch off, doors open for 2 days
    if you need an engineer
    http://www.ukwhitegoods.co.uk/search/fi … e-engineer
    Stretchy79
    Re: Kenwood FF
    Hi Dave.
    Just seen this. Will try that first. Would it possibly be a temp sensor? Stopped doing it and it’s been ok, just starting up again.
    #454812
    Re: Kenwood FF
    if it was a sensor I cant see it going ok and going faulty again sensors normally fail and have to be replaced
    Stretchy79
    Re: Kenwood FF
    Ok appreciated. Must be something electronic or possible door seals.
    Thanks again
    #454814
    Re: Kenwood FF
    if doors seals were faulty you would have more ice and snow then the north pole
    electronics is possible as the build quality of Kenwood is not that good
    Re: Kenwood FF
    On those, the fan motor is a prime suspect. 😉
    If you need one, it’s this one:
    https://shop.ukwhitegoods.co.uk/3059900 … -fan-motor
    Stretchy79
    Re: Kenwood FF
    Thanks guys. Ok so narrowing it down lol not many electronic components apart from pcb really that’s nothing too major.
    Kwatt the fan motor seems to kick in well but if that was not working correctly and pushing the cold temps about would that make it bleep?
    #454817
    Re: Kenwood FF
    If it’s air driven and the air doesn’t flow, it won’t cool correctly, you’ll erratic temperatures at times and perhaps a big block of ice where you can’t see. All in all, not a lot of fun stuff.
    I just know that on those units, among others, those cause problems and are common so, worth checking.
    Stretchy79
    Re: Kenwood FF
    Brilliant. Thank you so much.
