Kenwood Food Processor Problem
Home Forums Public Support Forums Help And Support Other Appliances Kenwood Food Processor Problem
  • #93669
    annelize
    Hi, would be really grateful for any advice.
    I have a Kenwood FP700 food processor which has served me well for years, but hasn’t been used for a while.
    The on/off switch now seems to be completely stuck in the 0 position – I can’t move it at all. The bowl and lid are correctly positioned when I try to turn it on.
    I’ve unscrewed the top (the platform where the liquidiser sits) to try to see what’s happening, but I can’t work out how to get it off – if I force it, I’ll break it.
    If anyone has any thoughts/suggestions, I’d really appreciate it.
    Many thanks in advance!
    #455195
    Re: Kenwood Food Processor Problem
    there can be two ways of stopping units like this from turning on for safety reasons
    mechanical
    and a mixture of mechanical and electrical
    if the switch is jammed then it may well be a mechanical interlock
    check again the bowl is locked into place in the correct orientation and the lid is on, again in the correct orientation
    I notice that this unit also has a liquidiser output. if the liquidiser bowl is on check that is locked on correctly if not is there a lid to protect the drive output that needs to be locked into place
