kenwood KBW8 ST2A Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › kenwood KBW8 ST2A This topic has 12 replies, 3 voices, and was last updated 17 years, 4 months ago by LittleMan. Viewing 13 posts - 1 through 13 (of 13 total) Author Posts November 15, 2008 at 9:08 am #41046 LittleManParticipant Hi This dish washer over fills can any one tell me the location of pressure switch or water level sensor Many thanks Les November 15, 2008 at 6:02 pm #268604 Penguin45Participant Re: kenwood KBW8 ST2A Usually front right corner. Think Indesit slimline, just worse. Much worse. Chris. November 15, 2008 at 6:11 pm #268605 smartinParticipant Re: kenwood KBW8 ST2A when you say overfills do you mean the base has flooded ? if so ask what tablets she is using, if she washes stuff in sink 1st ? are they still using salt ? November 15, 2008 at 8:28 pm #268606 LittleManParticipant Re: kenwood KBW8 ST2A Hi Smartin It overfills as soon as you turn it on the water level gets to high and leaks into base Les November 15, 2008 at 10:07 pm #268607 smartinParticipant Re: kenwood KBW8 ST2A if you are lucky base panel will come off to gain access, if not then sidepanels off to get in there . November 15, 2008 at 10:37 pm #268608 LittleManParticipant Re: kenwood KBW8 ST2A any idea what to look for thanks Les November 16, 2008 at 12:41 pm #268609 smartinParticipant Re: kenwood KBW8 ST2A blockage or operation of pressure switch i would check. November 16, 2008 at 1:09 pm #268610 LittleManParticipant Re: kenwood KBW8 ST2A Hi This dishwasher has not got apressure switch awere else would i look Many thanks Les November 16, 2008 at 1:18 pm #268611 smartinParticipant Re: kenwood KBW8 ST2A then i would think it would have a flow jug to meter the water into the machine check operation and connections on that and pcb end . November 16, 2008 at 1:21 pm #268612 Penguin45Participant Re: kenwood KBW8 ST2A KDW8, btw, if that helps anybody. Chris. November 16, 2008 at 3:49 pm #268613 LittleManParticipant Re: kenwood KBW8 ST2A chris can you explain please Les November 16, 2008 at 4:21 pm #268614 Penguin45Participant Re: kenwood KBW8 ST2A There doesn’t appear to be a KBW8 – there is a KDW8. BTW = by the way. November 16, 2008 at 4:38 pm #268615 LittleManParticipant Re: kenwood KBW8 ST2A sorry Chris It is a KDW8 Author Posts Viewing 13 posts - 1 through 13 (of 13 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
