Is there a common problem related to leaking on these, Have found the banjo seal at the rear of the condenser unit saturated.
To strip these down it appears that they have several seals on the related parts behind the back panel also rear fan stuck on so may have to replace if this breaks, is it recommended to change these other seals?
