Kenwood KDW 1247
Viewing 1 post (of 1 total)
  • #59643
    alfie
    Showing F4
    On tipping machine back a load of water flowed out of base plate. I suspect its over filling but there dos’nt seem to be that much water inside .
    I have observed flow chamber with left side removed, it seems to fill properly with no sign of any dirt in there e.g. like bosch. Water enters chamber from inlet valve through white hose. Two small bore black hoses leave chamber one to the water softener the other to the sump does it fill through this sump hose. Niether of these are blocked.
    Where the chamber fixes to the upper leftside of d/washer is this just a breather ❓
    Is there a pressure swt and if so where is it ❓
    If not what controls the water flow ❓
    Can someone provide me with a bit of training here or suggest a cure.
    I have read all the Kenwood posts using search and realise engineers take a dim view of these machines. It may be another for crushing.
