Kenwood KDW12ST3A not washing lower level
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Kenwood KDW12ST3A not washing lower level
  • #65292
    howmanymilestogo
    Hi. Firstly I wanted to say a big thanks for the help you gave me about 4 years ago to fix my Servis washing machine and supply the parts at great reduction. The machine is still going strong and not adding to landfill.
    I now have a dishwasher problem I’m hoping for some help with please. It is working and I have not changed the way the pots are stacked inside but the bottom level is no longer washing properly from underneath. The details are:
    – Plates on bottom mostly cleaned well
    – Underneath of pots left dirty – eg bowls if placed upside down
    – Top level is washing very well.
    – If the door is opened mid cycle, the lower spinner doesn’t appear to have moved.
    So, I think any washing effect is from the top spinner only, and there is no water coming up from the bottom spinner, or not enough for it to spin. I have checked:
    – Spinner is not clogged up – have removed and poured water through all holes
    – Nothing is obstructing lower spinner
    – Filters are all clean
    – Feeder pipe to lower spinner isn’t blocked at the spinner end of the pipe (inside the dishawasher)
    Is there just one pump on this model, with a splitter feeding to two spinners? I’m thinking I might need to check for blockages at the splitter/pump end but am not sure where to find this.
    Any help/guidance very much appreciated.
    Serial number is 650 S/N 002141 in case that’s useful.
    #359983
    It may well be that the 1/2 load flap on the motor may well have disintegrated and now blocks that half of the wash.
    Bryan
    #359984
    howmanymilestogo
    Re: Kenwood KDW12ST3A not washing lower level
    Thanks Bryan
    Is that something I can look at myself? Am presuming I’ll need to get at the it from the back or underneath?
    Any pointers before I get the screwdriver out would be much appreciated
