kenwood kdw23a e3
  • #64519
    keithwilliams
    hi every body
    been to this today throws up e3. any ideas.
    what it isnt is
    heater element is ok as it does heat and reads ok on meter
    there is not a pressure switch on spray pump outlet.
    there is no leakage in the base.
    it does fill/drain/spray/heat. heated to 60 degrees on glasses wash so temp seems ok.
    the only thing it didnt do was open the soap box even though it did heat. do you think a faulty soap box would give e3 code?
    thanks
    keith
    #357290
    mackos
    Re: kenwood kdw23a e3
    did you get anywhere with your Kenwood d/w E3 fault as I have to go look at a Kenwood KDW12SL3 tomorrow with a E3 error code.Thanks Mack.
    #357291
    clockworkone
    i may be wrong but i think this(kdw12) may be a multibranded machine ie haier/belling/powerpoint.couple of issues relating to e3 fault.one is temp sensor,the other is a pressure sensor inline with heater(follow heater wire which may be pink)sometimes if you add an extra 1.5 litres of water after it has filled it may trigger pres sensor to work to prove point.
    #357292
    HI
    If the extra 1 1/2 ltrs of water works then there is a modified pressure switch available as a gorenje part.
    bryan
    #357293
    clockworkone
    bryan do you have a part no for the modified pres switch.paul
    #357294
    Gorenje part 225374
    Bryan
    #357295
    clockworkone
    cheers Bryan.
    #357296
    mackos
    fixed my one today, it was the capacitor for the motor. Cheers Mack.
    #357297
    keithwilliams
    Thanks for capacitor tip. With regards to other comments thank you but it was heating to correct temp. (used digi thermometer). And it was spraying.
    K
