Kenwood KDW243A Dishwasher Lower Door Seal/Gasket.
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Kenwood KDW243A Dishwasher Lower Door Seal/Gasket.
Viewing 1 post (of 1 total)
  • #57380
    thisispaulsmith
    Looking for some help/advice with my Kenwood integrated dishwasher. It’s leaking water from the lower part of the door. I’ve had the front off and taken the lower metal cover so I can see the gasket clearly.
    Water is splashing underneath the lower seal, as it appear rippled/wavey and not touching the base all the way across. Water also seems to be coming round the side but that seems less of a problem. The main larger seal just seems to pull out and easily replaced however the lower one that I need to replace seem glued in place. How do I remove and replace this seal?
    I’ve seen replacements online for £2.99.
