kenwood kdw243a error code E4
Home Forums Public Support Forums Help And Support Dishwasher Help Forum kenwood kdw243a error code E4
  • #23812
    popvase
    Just installed the above and set to rinse to try…forgot to take the bung out of the sink waste dishwasher adapter! Realised the mistake but now have E4 and teh machine pump continuously operating despite no water left to pump…is there a simple solution? 😕 many thaks
    #199447
    Re: kenwood kdw243a error code E4
    Pull it out, un-plug it, tip it back gently and wait for the water to stop coming out from underneath. Towels down, obviously. It should reset and you can have another go.
    Hope you took out an extended warranty on this one………
    popvase
    many thanks penguin45 that solved it…
    I wish I had found this site before we bought the kenwood 😳
    #199449
    Daniel140280
    As above, I’ve had the e4 code and done as noted and problem 1 solved. The leak was located where the tube bringing in water at top of machine meets the ‘nut?’ at the top as the screw connection has deteriorated. What I need is a spare – but not sure what it is called. Alternatively, as machine installed early 2007 is it worth it?
