KENWOOD KIFF7017 Integrated 70/30 Fridge Freezer seems to run a-lot
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum KENWOOD KIFF7017 Integrated 70/30 Fridge Freezer seems to run a-lot
Viewing 1 post (of 1 total)
  • #97486
    ambassadorsam
    I’ve got a brand new (7 day old) integrated fridge freezer, model above. However, I seems to run a lot and I seem to be following the same routine. It seems to run alright in the day (usually set at 4 degrees c, it’s avdegrees setting). Occasionally running and then stopping. However it seems to every afternoon start running and then not turn off all afternoon or evening. I then usually turn the setting up to 5 degrees, it stops running and then put it back down to 4 degrees and it doesn’t run any more. I have been doing this every evening. It then seems to be alright through the rest of the evening, morning, daytime until the afternoon when it starts running again. It makes an occasional single knock noise, usually a few minutes after it stops running. Is there something wrong with it?
