Kenwood KTLD60X15 (1911031693) Fridge Display
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Kenwood KTLD60X15 (1911031693) Fridge Display
  • #100054
    jontymox
    Good afternoon all,
    A friend called to see if I could have a look at their Kenwood fridge, whereby when switched on at the socket the display lights up for a maximum of 2 seconds, before failing.
    If switched off, and then back on, the above fault recurs.
    The connections to the display/control unit appear fine, and I suspect the unit.
    However, I’m not a refrigeration specialist, so wonder if there may be an underlying problem, as I don’t wish to replace the display/control board if that isn’t the cause.
    Many thanks,
    jonty
    #479055
    Specialist01269
    Hi Jonty: I’m not a refrigeration engineer but with any fault like that, if your thinking board fault: I’d be looking for faulty electrolytic capacitors first, i.e domed tops & leakage around the bases.
    #479056
    Specialist01269
    Forgot to mention the often overlooked dry joints.
    #479057
    adv
    cant see the refrigeration side or compressor having anything to do with it .. got to be the board surely
    #479058
    jontymox
    Good afternoon chaps,
    Replaced the board on Saturday morning, and all ok. (thankfully not a wiring harness or other fault)
    Many thanks,
    jonty
    #479059
    Specialist01269
    Glad you got it sorted & thanks for the update, maybe you can repair the old board and keep as a spare.
