Kenwood USA fridge freezer KSBSDIX16 — Not running
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Kenwood USA fridge freezer KSBSDIX16 — Not running
  • #98869
    asp11
    The lights inside, front display panel and cooling motor are on BUT the compressor isn’t starting and there’s no clicking coming from the PCB at the rear…..
    I went for the PCB being the obvious error in my opinion but after fitting a new one today, waited 40mins…… I had the same result???
    The display shows -22 +3 but it clearly isn’t correct because the compressor isn’t running…… Not sure what else it can be really!!
    ANY ideas please?
    Brett
    #474091
    has the variable frequency board gone
    got a local fridge guy who says these go a lot
    part no K1939380 or HK1939380
    no stock connect but Aswo have them in and cheaper
    asp11
    I wasn’t sure what that part attached to the compressor does, so went for the pcb…… So if its a common part that fails according to your fridge guy then thats good enough for me Dave……… I dont have an account with AWSO so will have to go with Connect or apply for an account?
    Thanks again
    #474093
    the compressor is a 3 phase motor. the invertor changes the single phase ac supply to 3 phase to power the motor. Most of these inverters also allow them to control the speed of the motor to meet efficiency targets
    apply for aswo account it will be worth it
    connect take the mick with prices, you need something to compare so you will know
    connect price to me £45.88
    aswo price £37.00
    no contest
    https://shop.aswo.com/aswoShop/startPage.faces?storeId=509
