KGN36NWEAG/05 Bosch Fridge Freezer Turning Itself Off
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum KGN36NWEAG/05 Bosch Fridge Freezer Turning Itself Off
  • #103370
    RustyH
    I have recently lost 2 loads of food in my fridge freezer because it has turned itself off. It is a 3 year old Bosch series 2 model.
    When I opened the fridge door, the interior light didn’t come on and it appeared to have no power. I unplugged it and checked the fuse, which was OK. When I plugged it back in, the fridge freezer began working normally and the temperature alarm sounded until it had cooled down. First I assumed there had been a power glitch or the mains plug wasn’t seated properly but 2 weeks later it did the same thing and I lost another load of food. When it turns itself off I get no warning because the alarm doesn’t sound.
    It is out of warranty now so the minimum call out fee is £109 from Bosch. I wonder whether an overheating sensor is tripping? I have it in the kitchen which doesn’t get particularly hot and both sides are in free air. Looks like a new control module can be picked up for about £90 but if it is a dodgy temperature sensor, that won’t help.
    Any suggestions gratefully received.
    Russ
    #492888
    if temp sensor had failed you should still have lights
    assume you have tried a different socket just in case but it does sound like a power chip failure on the circuit board
    lookied up the module up and its £66 so £90 sounds a bit steep
    cant promise I am correct but module sounds likely
    RustyH
    Thanks for the fast reply. Yes, I was looking at the wrong module and have found the right one now. Btw, do you know if it is possible to find a wiring diagram or service manual for this model or do Bosch keep them all locked up?
    Russ
    #492890
    no chance, unless you have a freindly bosch service agent you have no hope
    another option that may be cheaper is
    https://www.easypcb.co.uk/
    not used them myself but other forum members have so cant attest to reliability but your fault does sound like a power chip which are really cheap and easy to fix
    RustyH
    Thanks for your help. If it does it again, I think I’ll try a new module as it isn’t that expensive and minimises down time, otherwise I would try the PCB business.
    Russ
