Wonder if I could have some advice for a neighbours fridge (Bosch) whos light recently blew. On replacing with the correct part, the light works, but when the door is closed (or switch is closed), the light dims but is not extinguished. Is there a reason for this or has the control circuit failed please?
If the appliance is located in a room which has a lower ambient temperature then 18C, then a reduced illumination of interior light is activated when the door is closed.Therefore it is normal operation under that condition so no fault :tup: .
