Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › KGV3120GB01 Not Running
- This topic has 9 replies, 4 voices, and was last updated 19 years, 4 months ago by
Broadband.
November 20, 2006 at 5:08 pm #22715
Broadband
ParticipantAnyone help on Bosch F/Freezer motor not running. Have checked motor & overload, there is no power to overload. Have had module tested by QER, even tried a new one. Thermistors appear foamed in. They have resistance, but I don’t know what they should read. Any help appreciated.
November 20, 2006 at 11:52 pm #195917roly16
ParticipantRe: KGV3120GB01 Not Running
If it runs and gets down to temp, cuts out and won’t re-start until you switch it off at the mains and then switch it back on again it needs the thermistor by-pass modification doing. If you think that’s your problem I’ll put another post on tomorrow with how to do it. It’s a bit late to do it now.
Geoff
November 21, 2006 at 7:40 am #195918admin
KeymasterGeoff,
Please post to me also…
Thank’sNovember 21, 2006 at 8:56 am #195919Broadband
ParticipantThe F/F does’nt run at all. The control panel lights up, everything is normal, but the motor does not start.
November 21, 2006 at 9:28 am #195920Simon46
Have a look here Guys. Search Facility is useful.
http://www.ukwhitegoods.co.uk/modules.p … v3120gb+01Regards
SimonNovember 21, 2006 at 2:11 pm #195921roly16
Thanks Simon, I knew I’d seen it here before but was was just going to re-write it as it was easier than searching for it.
To sum up; if it’s a 4-wire thermistor connector, cut and join wires 1 and 3 to short out the thermistor. Don’t touch 2 and 4.
If it’s a 3-wire connector, cut and join wires 1 and 2, but this must be done further back where [black] wire 1, which is a common connection to the 2 thermistors, separates out into the 2 blue wires, one going to each thermistor. You cut wire 2 [dark brown] and the blue wire that forms part of the same thermistor as wire 1 and join them thus shorting out the thermistor. You are effectively doing the same job as if it was a 4-wire connector.
November 21, 2006 at 5:27 pm #195922Broadband
ParticipantI’m sorry for being thick, but, do you join the plug leads or the thermistor leads after cutting?
November 21, 2006 at 5:59 pm #195923roly16
You join the ends connected to the plug. The pcb then sees a short circuit instead of the thermistor resistance. The thermistor is then redundant; just tape up the ends of its wires.
November 21, 2006 at 9:41 pm #195924Simon46
No probs. Ta for 20Quid. Enjoyed Posh Panini in Alderley edge and treated van to some Fuel 😆
S.
November 22, 2006 at 3:12 pm #195925Broadband
ParticipantThanks Guys, Have been back, all now OK!!
