Kitchen hood without motor
Home Forums Public Support Forums Help And Support Other Appliances Kitchen hood without motor
  • #94897
    Gms
    I bought a new apartment with a central ventilation system that has a kitchen hood withouth a motor. It seems to me that it doesn’t do much.
    how can I know whether is working? It is not supposed to make any noise right? It is a pelgrim it has a switch for the lights and one for what I understand is a valve that open. It also has a dial with a 1 a 2 and a 3. cannot figure out if it does something.
    any ideas on how to understand if it is working and connected properly?
    thanks,
    gladys
    #458689
    I would assume the central fan unit would be controlled by the switches on the unit. if its working correctly then if boil a pan on the stove you should see the steam going into the hood
    find the central fan unit, a lot of them are stuck in a cupboard somewhere in the flat. then operate the switches and see if the unit starts up
    has your unit got a model no ?
