Knob removal – tricity bendix 1053w
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Knob removal – tricity bendix 1053w
  • #8969
    Hi all, the water always flows into the same compartment on my machine, and I can see the problem – a tiny peice of plastic on a lever that is moved by the timer as it goes through the settings has broken off. Although I can see the part I need to get to, how do I remove the knob/timer cam assembly so that the offending item can be fixed? With a little space the lever will just rotate and pop out but I don’t want to force anything apart, else the problem will get bigger!
    Thanks in advance for any help!
    #131434
    Re: Knob removal – tricity bendix 1053w
    It’s a tricky little job you got there Wayne. Sadly for certain legal reasons I cannot advise on DIY repairs as such, suffice to say though that the Control Fascia is held on by several lugs around its perimeter that need careful consideration 😉
    My official advice is that you call in an expert and get it sorted, cheaply and easily…try this link for someone in your area:-
    Repairs@
