Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Known Test Procedures
- This topic has 20 replies, 13 voices, and was last updated 20 years, 3 months ago by
kwatt.
December 28, 2005 at 12:25 am #14324
KeymasterPlease post any known test procedures here. Please include the model range if it works across a range.
Ta
December 28, 2005 at 12:41 am #159010iadom
ModeratorRe: Known Test Procedures
As this is more of a ‘test’ procedure I have copied it into here. it is also to be found in error codes thread, will dig out a few more when the time allows. 😉
Hotpoint WMA 30/40/50 Last Error detected codes
Ensure that the main selector switch is in the Off or O position.
Press and hold the Super Rinse and Rinse Hold buttons whilst selecting H on the selector knob, and continue to hold for five seconds.
The ‘Super Rinse’, ‘Rinse Hold’ and ‘Wash’ LED’s will now be flashing.
Press the Start/Cancel button for two seconds.
The ‘Rinse Hold’ LED will be lit and the ‘Super Rinse’ LED will be flashing.
The ‘Final Spin’ LED could be on or off at this stage.Press the Rinse Hold button briefly.
The ‘Rinse Hold’ LED will be flashing & the ‘Super Rinse’ LED will be on steady to indicate the last error routine has been initiated.
Rotate the main programme selector knob slowly anti-clockwise to programme A
Slowly rotate the selector switch clockwise through four positions A to D inclusive, pausing briefly at each programme position. Starting with A make a note of the ‘Final Spin’ LED status. it will be on or off.
When the selector knob reaches D you will have a series of Ons and Offs . This 4 bit binary code should be recorded and checked against the error codes in the following table.
……………………………………………………..A………..B………….C………..D
No spin due to O.O.B……………………….on………off………..off………off
Start butt pressed with door open…….off……….on…………off……..off
or O/C interlock.Failure to fill in allotted time……………..on……….on……….off……….off
Failure to pump out in time allowed……off………off………on……….off
No feedback from thermistor when……off………on……….on………off
heating.Tacho error…………………………………….on……..on……….on………..off
No feedback from tacho…………………..off……….off………off……….on
Motor O/CMotor triac short circuit…………………….on……….off……….off……….on
That was a bit of a pain to get lined up but I hope someone may find it useful.
December 28, 2005 at 8:53 am #159011Martin
ParticipantRe: Known Test Procedures
A word of caution over copying text direct from manufacturers service manuals as many are held in copyright by them. Reproducing such information on this site may be in breach of this ❗
December 28, 2005 at 9:27 am #159012iadom
Point taken Martin, I do take particular care not to scan and post direct, and often do a little précis on the text as well. 😉
January 4, 2006 at 9:28 pm #159013DentedPorsche
Whirlpool Dolphin Range of Dishwashers.
Make sure it’s empty before doing this.
Select the first program, normally rinse.
Switch off. Press and hold the start button and switch back on. Light will start to flash, release button. Press the start button and close the door. Machine will now go through a diagnostic by filling, washing, heating and draining. Any errors will be shown by the start button light flashing a code.Brian
January 11, 2006 at 6:02 pm #159014VillageIdiot2
BlockedRe: Known Test Procedures
Hotpoint Mistral Range of F/F
Test Procedure for these are –
Turn appliance off at the mains, press and hold SAVE and switch on at mains and release SAVE.
The sequence will now start –
Evap defrost heater will activate for 10secs, then
Gutter heater 10secs, then
F/F LED display 10 secs, then
Evap fan 10 secs.If a fault is found, the following error codes will apply –
E1 – Freezer thermister o/c
E2 – Freezer thermister s/c
E3 – Fridge thermister o/c
E4 – Fridge thermister s/c
E7 – Evaporator thermister o/c
E8 – Evaporator thermister s/c
EA – No feedback from baffle motor switch
EB – fridge baffle motor running constantly
EE – Defrost heater timed out.Hope these help!
February 27, 2006 at 12:52 pm #159015Fairdeal
Quick Function Test for Baumatic BDW13/14/45.1
The following quick test procedures are used to conduct a quick test for a particular function or functions without waiting for a whole normal washing cycle. It offers a good tool to make test and diagnosis in visit to clients. The main steps and display code are as follows:
Step No.
Test Stage
Display Code
Status Explanation00
Initiation
17
Power on; ready to run01
Input Water
16
Input water valve on, in putting water for 15s02
Washing pump
15
Washing pump on, 3s delay to check water
level; washing for further 10s after supply water
valves off
03
Dispenser
14
Dispenser on for 10s04
Heating element
13
Washing pump on, heating elements on, for 15s05
Re-generation value
12
Re-generation valve is on06
Draining pump
11
Draining pump on, draining for further 20s after
the switch is in position07
Test Finishing
10
Beep once, appliance stopsProcedure to enter this quick test mode:
1. Press the timer button and the power on button at the same time;
2. Then the initial stage is set with ‘17’ appearing on the LED display;
3. We can skip any step in the operating process by pressing programme button P on the
panel. And the LED display is decreased by 1 per step to 16 –15—14—13 etc to 10. The
sequence of this step is listed in the above table.
Hope it helps.
August 3, 2006 at 7:48 am #159016MKR
washdoctor wrote:Hotpoint Mistral Range of F/F
I would just like to add: that if you switch the appliance on with the door open, it will do a short test and then fire-up the compressor… very useful if you don’t want to wait for the end of a defrost cycle.
August 8, 2006 at 4:16 pm #159017iadom
Hotpoint WM/WD Ultima range Wet Test .
Hold down buttons A & C then press On.
Press Start and machine should begin the sequenceThere are ten steps in all.
Always allow sequence to finish or press Cancel to clear.
Step.
1. Fill cold for 40 secs, no drum action.
2. Temp controlled fill to 50° with normal action at wash speed.
3. Pause for 20 secs.
4. Fill from Fab Cond valve.
5. four tumbles of normal action at wash speed ( as temp reaches 50° display will show temp instead of step nymber)
6. Pump for 40 secs without agitation.
7. Pump & spin at 1000rpm for 30 secs.
8. Pump & Spin at 1200 for 10 secs.
9. Pump as drums slows to a stop.
10. Stop.August 8, 2006 at 8:43 pm #159018cab
LG test sequence some models two versions
press Rinse & Spin buttons then turn on.
all lights on display light, each time you press the start/pause button checks a feature,
1 press tumble clockwise 40-50 rpm (shown in display)
2 low speed spin 600-650 rpm (sid)
3 high speed spin uptp max (sid)
4 fill thru prewash water level (sid)
5 fill thru main wash (sid) or hot valve
6 fill thru hot valve (sid) or main wash
7 fill thru dryer if applicable anti clock tumble
8 tumble anti clock 40-50 rpm (sid) or heater
9 heater on for only 3 seca or drain
10 circ pump on or turn off
11 drain pump on
12 turns offcant test fill on cond compartment!
August 8, 2006 at 8:52 pm #159019cab
beko wma1715s
with power turned off select 90 cotton position
press & hold the start/pause switch on, start button will flash after 3 sec.
each push of start button will test a function
1 all leds flsh
2 water fill thru pre wash
3 water fill thru main
4 water thru conditioner
5 hot fill
6 heater on will fill to level if below
7 clockwise drum to 52 rpm
8 anti clock to 52 rpm
9 drain
10 spin to max
11 fill to check leaks
12 endAugust 8, 2006 at 9:23 pm #159020cab
Tricity AW1400 Electrolux Zanussi
press & hold start/pause and any other option button
turn dial 1 step clockwise lights should start to flash after 2 secseach turn clockwise operates a function
step 2 door lock water thru wash
3 water thru pre wash
5 does nowt
6 heating max 10 mins *
7 checks tub for leaks, 55rpm clockwise- 55 anti -250 rpm spin
8 drain & spinturn to position tento display fault code
August 8, 2006 at 9:34 pm #159021cab
Zanussi washer IZ style many models
push button control with or without digital display
FLE14… etcpress both start & skip buttons ( square & triangle)
switch on hold start& skip for 4 secsdisplay board is checked by lighting each led in sequence.
each press of the fabric button tests functions.
1 fill main
2 fill pre wash
3 fill conditioner
4 hot fill if applicable
5 heating (with circ pump if applicable) max 10 mins
6 checks tub for leaks 250 rpm spin
7 drain and spin to max
8 dry if applicableend
March 13, 2007 at 5:45 pm #159022kwatt
KeymasterRe: Known Test Procedures
Hoover “Nextra” Washing Machines
Starting The Test Sequence
1. Press and hold button 1
2. Turn the program selector knob clockwise 2 steps
3. As soon as the LED on button 1 lights, release the button
4. All LEDs should light
5. After three seconds but within 5 seconds press button 1
6. After correctly set the two rows of LEDs, residual time/time delay and buttons should flash alternatelyAuto-Test Sequence
• Fill to first level through pre-wash compartment, hot fill energised where present. If fitted the recirculation pump is also energised.
• One second pause
• Heater energised for approx 16 seconds and distribution cam on soap drawer moves the spray nozzle to main wash compartment.
• Cold valve, hot, where fitted and recirc pump, where fitted, energized. Main motor tumbles anti-clockwise at 55rpm for approx 13 seconds.
• Motor paused, filling continues
• Cold valve, hot, where fitted and recirc pump, where fitted, energized. Main motor tumbles anti-clockwise at 55rpm for approx 13 seconds. At this point, by pressing button “3” the drum speed can be reduced to 35rpm.
• Drain pump energised until pressure switch detect that the machine is empty
• Short spin, roughly 27 seconds at half the maximum rated speed
• End of test
October 2, 2007 at 11:13 pm #159023Beever
Beko WMA765S
Flash Functional Test Program
Entrance to the test mode:
1. Turn off the machine from On/Off Button
2. Turn on the W/M from the main switch, while pressing “start/pause/cancel” button and the selected program is cotton
90. Start icon will start to blink within 3 seconds. At the moment, you can see the code of failure in follower LEDs or on 7
segment.
3. After seeing the failure, erase the failure by pressing start/pause/cancel button 3 seconds without losing any time
4. After erasing the failure code, you will be in functional test mode. Each push to the start / pause / cancel button will
represent one function.
Functional Test Sequence:
1. All LEDs on the board will start to blink after the door is locked.
2. Take in water from pre-wash compartment
3. Take in water from main wash compartment
4. Take in water from softener compartment
5. Take in water from main wash compartment if the W/M has a hot valve option (If not this step will be skipped)
6. The heater will be ON. If the water level inside the tub is not enough for the heater to switch on then all valves will be
turn on to fill the level.
7. Clockwise motor rotation with 52 rpm
8. Counterclockwise motor rotation with 52 rpm
9. Draining
10.Spinning up to maximum speed.
11. Turn on all the valves to fill a certain level in a short time for water leakage test on the production line.
12. End
13. You can get off the test mode by turning the WM off.Faults:-
H1 : NTC OPEN CIRCUIT OR SHORT CIRCUIT ( 10000 )
H2 : HEATER OPEN CIRCUIT ( 01000 )
H3 : HEATER ALWAYS ON ( 11000 )
H4 : VALVE TRIAC SHORT CIRCUIT ( 00100 )
H5 : PUMP OPEN CIRCUIT ( 10100 )
H6 : MOTOR TRIAC SHORT CIRCUIT ( 01100 )
H7 : PRESSURE SENSOR FAILURE ( 11100 )
H11 : MOTOR / TACHO OPEN CIRCUIT ( 00110 )Help:-
Not able to select any program ( As warning softener led blinks in program follower ) IF Yes:- Check program selector resistance and compare
the value with the table:-1. Position ~1 Kohm
2. Position ~2 Kohm
3. Position ~3 Kohm
4. Position ~ 4Kohm
5. Position ~ 5Kohm
6. Position ~6 Kohm
7. Position ~7 Kohm
8. Position ~8 Kohm
9. Position ~9 Kohm
10. Position ~10 Kohm
11. Position ~11 Kohm
12. Position ~12 Kohm
13. Position ~13 Kohm
14. Position ~14 Kohm
15. Position ~15 Kohm
16. Position 16 Kohm
If All the resistance values ok:- Check connection between program selector and main board. If there is not a problem at connection change the Main PCB.
program selector and main board.If All the resistance values are not ok:- Change the program selector
Is RINSE led blinking in the program follower ? If Yes:- Check Valves/ Voltage to valves/ Water supply to valves.
Is MAINWASH led blinking in the program follower? If Yes:- While programming card, an error may have occurred in one of the processing stages,
change the Main PCB.) -
