Home › Forums › Public Support Forums › Spare Parts Help › Kuppersbusch Dishwasher – replacement spray arm
- This topic has 2 replies, 2 voices, and was last updated 16 years, 11 months ago by
sennapod.
May 15, 2009 at 11:36 am #45733
sennapod
ParticipantHello
The polypropylene lower spray arm in my IGV659.2 model dishwasher has split open – due to plastic fatigue (?) – the loss of water pressure means neither it nor the top arm will rotate.I am having real trouble locating a replacement part. Kuppersbusch (aka Teka) have outsourced all their tech-support and spares to Partmaster (PM), who themselves deny any knowledge of this part (despite the day-before telling me it WAS available). Teka variously tellme I need part no 426640 or 422640 (one of these nos is almost certainly wrong).
Can someone offer any advice on whether any Bosch/Neff etc parts are interchnangeable (they seem to be – the Bosch/AEG/Neff models I see in shops seem to be 99{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} identical internally), or alternately help my find a Kuppersbusch part from another model which will work.
Partmaster do have slighlty different (s-shaped, mine is straight) arms for other Kuppersbusch DW’s (eg IGV692.1 model – is there any difference?) – but I am not 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} convinced the parts are compatible – certainly the push-in-connector looks the same, and I assume overall dimensions are fairly standard.
Eg http://www.partmaster.co.uk/cgi-bin/pro … =&part=armEspares also list a Bosch part (also s-shaped) which also seems identical-ish. http://www.espares.co.uk/part/dishwashe … ay-ar.html
Many thanks to you all.
Model IGV659.2 (other numbers SGVKBH2, FD8102, 430113, serial no(?) 1010212022357490113May 15, 2009 at 1:43 pm #286819kwatt
KeymasterRe: Kuppersbusch Dishwasher – replacement spray arm
I don’t think the Bosch one available here is right, I just have a bad feeling about it. It’s possible that it’s the same but I’m not convinced.
The IGV659.1 looks to be identical to the IGV659.2 with some minor cosmetic differences but, it’s really hard to tell from the Teka disc as it’s as old as the hills. I can only confirm that part number 422640 (available here) fits the early version but, I’m pretty confident it’s the exact same as the later version.
HTH
May 18, 2009 at 8:05 am #286820sennapod
ParticipantRe: Kuppersbusch Dishwasher – replacement spray arm
thanks for that tip. I’m going to try the Bosch one first (as the price is so much lower) – have ordered it from this very website; and if it doesn’t fit I’ll try to return it and then go for the kuppersbusch-specific one.
