Kuppersbusch igv659.4/03 Dishwasher
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Kuppersbusch igv659.4/03 Dishwasher
  • #54262
    ray.t
    Been to this today customer complained that the machine would not drain.
    I switched it on and the first thing it did was drain the water out.
    I then checked all the usual suspects pump, flap valve, drain hose and all are clear.
    I ran the machine with the side off watching the matrix and the first time it pumped out I could see it go straight over and out, the next time it got to the top of the matrix but would not go over into the drain hose.
    I can see the matrix at the top is a bit cruded up. Could this be the cause or is it more likley to be a faulty drain pump.
    Ray
    #319009
    A1engineer
    Re: Kuppersbusch igv659.4/03 Dishwasher
    clean the crud in matrix, also check the pipe that goes between pump and matrix, platic push fit pipe, should just pull out
    #319010
    ray.t
    Hi I looked to clean out the matrix but I cant see any way of getting into it. Pipe from pump to matrix is fine.
    Ray
    #319011
    A1engineer
    #319012
    ray.t
    Its the big matrix it goes the width of the machine.
    Can these be cleaned out?
    Ray
