Re: Kyoto freezer , deluxe Ku9677
I will need more information to be able to advise on the fault.
Is the compressor motor hot and not making a noise.
Is the compressor hot but making a noise.
If the compressor is hot and not making a noise the compressor will need replacing and a regas.
If the compressor is hot but still running then it may have a leak and the leak would need repairing and a regas.
If the compressor is cold and not running it may be a PCB/Module Fault all the above faults are not cheap to repair and as this is now an old model it maybe cheeper to replace.
Bob
