Kyoto KU 127 shelf & drawer supports
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Kyoto KU 127 shelf & drawer supports
  • #58181
    Dove
    I have a Kyoto KU 127 11.8cu.ft. upright freezer from Iceland
    All the brackets which support the shelves and drawers have broken. I have tried gluing them but after a while they break again.
    There are 2 different styles of brackets as well as left and right ones.
    eSpares call the brackets a freezer block and are selling them for £19.99 each – I need 7 pairs!
    £280 on shelf supports seems very expensive and is a long way towards replacing a freezer which quite is a few years old.
    Are there any cheaper alternatives I could use? Or would I be better replacing the freezer?
    Any ideas or suggestions would be appreciated.
    Many thanks
    Lesley
    #333641
    don
    Re: Kyoto KU 127 shelf & drawer supports
    Hi Lesley
    No pattern parts showing on Google I’m afraid. If that’s the cheapest you can find them for I would definately replace it.
    If you need help replacing it, post up the physical size you are looking for and we’ll have a go for you.
    HTH 🙂
    Don
    #333642
    Hi Lesley,
    That price is a bit severe.
    Added them for you at a more sensible level here:
    http://shop.ukwhitegoods.co.uk/Refriger … pport.html
    HTH
    Dove
    Thank you K and Don.
    I think I might be better replacing it as the door seal isn’t brilliant either. Will probably leave it until this one goes and then go for a smaller one.
    Many thanks
