Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › L.G Pump
- This topic has 7 replies, 6 voices, and was last updated 16 years, 2 months ago by
peeler40.
January 12, 2010 at 7:20 pm #51573
peeler40
ParticipantL.G. Washing machine wm12336fd
Machine does not pump all the water out in the final spin . If you fill the the machine on a wash program ,then set the program to drain the machine starts pumping the water out but the program times out well before the machine has emptied .Any ideas .
Lucky GoldstarJanuary 12, 2010 at 7:34 pm #308569timdowning
ParticipantRe: L.G Pump
Blocked?
January 12, 2010 at 7:50 pm #308570peeler40
No it starts pumping fine then the display reads program end , and
there is still water in the machine .From pressing the start button ( with the program set to drain )to the display showing program end is less than
30 seconds .January 12, 2010 at 11:23 pm #308571leavemetogetonwithit
Pumps on these are not that reliable. I’d remove front panel and try running pump from a flying lead to see if it runs OK or packs in. If it runs OK then I should think electronics are implicated. Otherwise could be something wrong with p/sw?
Mike.January 13, 2010 at 3:46 am #308572gandh1
its not a machine thats recently been transported to a new home, where the waste was down a standpipe and is now fitted to a (blocked-off or bumged up) spike?
if i had a tenner for every call out that ive been to where ive exhausted all faults and THEN find out from the customer it was working fine in their old house… 👿
also went out to a h/p last week connected to a spike under the sink in the utility room where after the u bend it went directly outside.
turns out the u bend, even tho it was indoors, because sink was only rarely used it had frozen enough inside the u to cause the machine to time out.
January 13, 2010 at 9:27 am #308573cornwell40
Is this the one with the u bend built into the drain hose.
I’ve had partial blockages (coins) in those before now. Not easy to get to though without your old metal coathanger 😉TC
January 14, 2010 at 1:47 pm #308574peeler40
Thanks for all the replies , its looking like a module fault .
January 14, 2010 at 5:08 pm #308575Owain84
ParticipantIF you put these on drain the m/c will only pump for a few secs even tho window will read 1 or 2 mins put it on spin then see if it drains out
Dave -
