Hi, was called to this machine for a no drain problem, found pump burned out and nails jamming impellor.
Easy job, or so I thought. Now machine runs pump as soon as its switched on and continues even when a programme starts so machine then sits filling & emptying constantly 🙁
Thinking module has buggered triac or something, EMW dont seem to do them, anyone got any solutions please?
I know they are a pain to work on as the board is buried in silicone but it might be possible to trace the wiring from the pump to a component on the board which reads short circuit. Otherwise you could try QER.
Cheers Phidom, not really a fan of QER but will return to this machine to remove my pump and collect callout, will spend a half hour looking at the board, hate to see an otherwise good machine dumped 🙁
