L.G WM1080fhd Direct Drive drum bearing job
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries L.G WM1080fhd Direct Drive drum bearing job
  • #42400
    Seamy
    Got a call to look at one of these LG direct drive jobbies, 3 year old WM1080FHD, bearings noisy & report of brown rusty stain under machine at back.
    Never worked on a direct drive machine before. Is it straight forward enough to dismantle the direct drive motor off back & do bearing job or what should I look out for, any advise appreciated.
    Lucky Goldstar
    #273407
    PGS
    Re: L.G WM1080fhd Direct Drive drum bearing job
    Its probably one of the easiest bearing changes you will ever do.
    #273408
    Drum out the back – like Zanussi split tub, you’ll need a bit of space.
    Mike.
