Cluny range no model number, I’ve worked on these before and replaced a few selector switches without problems.
On the range the right side is conventional with grill, it has selector with a thermostat piggyback and a second thermostat for the left side has Gas oven. The right side main oven will not run it seems from
my tests I’m losing a neutral as phase to earth I get 230 and phase to neutral 5volts.
I replaced selector like for like, but still nothing. Stat is working fine but the indicator neons though functioning do not come on. The set up appears quite basic, no toc visible or thermal fuse.
All I can put it down too is faulty switch?8
