Lamber/Newscan N5 350E Glasswaher
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Lamber/Newscan N5 350E Glasswaher
  • #59112
    Hollytree_Technical
    Hi all
    Does anyone have a wiring diagram/service manual for the above machine please?
    Thank you
    Jeremy
    #336968
    A1TEC
    Re: Lamber/Newscan N5 350E Glasswaher
    I don’t think the do service manuals for these machines.
    What is the problem with it?
    John.
    #336969
    Hollytree_Technical
    Apologies that it has taken so long for me to get back to you.
    This is one of those machines that has never worked since before the current owner took over the premises. I have already had to wire up the level switch by guesswork, there is one wire coming from live, one going to the thermostats and one going to somewhere else (possibly timer), all the individual components appear to work ok when tested, when I turn it on then it will fill and the wash motor runs,however even though it fills ok it never activates the level switch to say that it is full – I have checked the hose and switch and cant find any blockages/leaks and have tried tilting the machine forwards slightly to try and force activation but it doesn’t, if I bypass the switch then it turns the wash motor and fill valve off but turns the heater on.
    I don’t normally deal with glass washers but am trying to help a friend out – should it run the motor when filling? and why doesn’t it run it when heating? – I suspect that someone may have played with it before me which is why I would like a wiring diagram so that I can check to see if they have mucked it up.
    Thank you
    Jem
    #336970
    A1TEC
    Some of these machines have a washpump and a rinse pump.
    Some will fill off the rinse pump and will not activate the wash pump until the wash temp has been reached.
    John.
    #336971
    Hollytree_Technical
    From memory I think that this one only has a wash pump – so you think that if I gave it longer to heat it might then kick in the wash motor again?
    Thank you
    Jem
    #336972
    A1TEC
    Worth a try or another look.
    John.
    #336973
    ring Chefquip 01299871856
    they are the Lamber agent and may sent you info
