Lamina Dishwasher LAM8601
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Lamina Dishwasher LAM8601
  • #89039
    ekphones
    Hi, looking for some advice please.
    Unable to select any programmes and start the machine.
    When machine is switched on, the red light (to the left of the temperature LEDs) comes on, and all of the green temperature LEDs illuminate briefly, then go out.
    The red LED remains on constantly, but the start button does not illuminate at all.
    I’ve removed and cleaned all of the filters, although they appeared to be fairly clean anyway.
    There was a small pool of water at the base of the machine (above the pump ?). I have dried out the water, but again no sign of any debris.
    Any advice would be appreciated.
    #440153
    GuyW
    Re: Lamina Dishwasher LAM8601
    [quote=”ekphones”
    Was this water in the under-tray that is fixed to the bottom of the machine? It sounds as if you weren’t looking at the very base of the machine as you say it was above the pump?
    Many machines have a cut-out float switch situated at the very lowest point of the undertray. It is designed to cut out if more than about 1/2″ of water accumulates in the tray.
    #440154
    ekphones
    Correct. The water was in the under tray.
    It’s now dried out, so I presume it’s not an issue with the cut-out float switch?
    #440155
    GuyW
    No, I don’t think so. The float switch should reset automatically, although I suppose in theory it might stick in the open circuit position.
    #440156
    mikehha
    did you sort this problem? I have the same problem . no water underneath in the tray lights just flash then dead.
    #440157
    adv
    hi i have same fault with one . anyone fix theirs ? am thinking pcb my self ?
    #440158
    adv
    any body suss this fault out ?
    #440159
    Function test for this machine
