Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Lamona 3301 Selector Switch
- This topic has 9 replies, 3 voices, and was last updated 7 years, 6 months ago by
tsayers66.
September 20, 2018 at 7:02 pm #94690
tsayers66
ParticipantHi,
I have identified the problem is with a faulty selector switch, a broken piece was lying on top of the oven, when I took it apart.
My problem is getting to the screws that hold it in place.
The 2 side screws release the front panel from the oven but dont give access to the selector switch screws, I can see the screws but cannot access them as they are still behind the front plate.
The front panel seems to be in 2 sections and I cant split them, seems they are somehow welded together?
Any help would be appreciated.
Thanks in advanceSeptember 20, 2018 at 7:31 pm #458016electrofix
ModeratorRe: Lamona 3301 Selector Switch
from what I can see the controls are mounted on plastic circles that lock into the front panel. There is a piece of metal that locks them into place allowing you to twist to unlock it and withdraw it
the control can then be just unscrewed and the circle replaced and locked againDave
September 20, 2018 at 7:37 pm #458017tsayers66
ParticipantRe: Lamona 3301 Selector Switch
Thanks for the quick reply, its the front plate that I cannot split, I cannot access the screw heads for the selector switch, it seems to be stuck together, I have attached a picture, there are 6 of these holding it together, hope this helps.
Cheers,
ThomasSeptember 20, 2018 at 7:45 pm #458018electrofix
don’t understand the picture
assume you want to remove the selector switch and to do this you do not need to remove panel. look where switch contacts panel or post a picture of that
September 20, 2018 at 8:00 pm #458019tsayers66
Yes its the selector switch I need to remove.
More pictures attached, when I remove the front panel by taking out the side screws, the front panel is still in one piece with no access to the selector switch screw heads.September 20, 2018 at 8:03 pm #458020tsayers66
Picture 1 is the back of the selector switch
Picture 2 is the outside of the front panel, showing a circle to the rear of where it is welded? together.
Picture 2 shows the front panel removed, I can see the screw heads through the hole in the front, but can’t get to them to take them out.
CheersSeptember 20, 2018 at 8:12 pm #458021electrofix
unlatch tab Yellow then turn to unlock
you can see the locking tabs red so it looks like its clockwise to unlock
September 20, 2018 at 8:17 pm #458022tsayers66
Thanks it worked, I will order the replacement now.
Thanks for your help and patience!
June 1, 2019 at 1:03 pm #458023Neil Wolstenholme
ParticipantHi, any trips on unrlatching the metal tab. Mine still won’t u lock. I have bent the metal latch straight. Is this correct?
June 1, 2019 at 3:05 pm #458024electrofix
Moderatorthe tab just stops disk from turning. once its clear the disk will unlock by turning
