Hello, I have a Lamona 8301 dishwasher and it seems to be stuck on the final cycle. It wont switch off at all, unless I manually switch it off. I have tried to “restart” by holding the cancel button in for 5 seconds to 1 min. I have switched it off at the wall. Checked all the filters are clear and they are.
Please help. Thank you
Perhaps there is water flooded down in to base and has activated a float switch to run pump continuously. Or maybe the appliance is not emptying the water completely, check drian hose is draining into a basin or bucket to make sure its not clogged.
Power of course if doing any tests.
Hello where would I find the float switch please. I have rung Howdens where I got it from (got a complete fitted kitchen with appliances from them and they said because I am not trade they can’t help. ……) thank you for your help.
