Thanks for that dave it turned out to be module. Now I have a LAM 8601 with the 2 and 3 light flashing and while they are flashing you can`t get it into a test cycle I can not find the code for this also. But if you leave it for a couple of days you might get one wash out of it before the lights flash again, there is no water in the base and pressure switch is fine. anyone know this or have come across this fault . thanks
yes main module looks ok I know there has been problems with the selector button module but I didn`t think it would throw up this type of fault. could be water damage on top edge of door?
