Lamona 8603 not running
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Lamona 8603 not running
  • #103527
    tfo98
    Dishwasher fills with water then seems to cut, I replaced the drain pump approx 2 years ago and have checked the inlet solenoid and motor with multimeter and both are well in range. Circulation pump is attached to motor but when I removed it I could spin the pump with my finger, no obstruction or blockage.
    After this cycle thing happens it attempts to fill with water again for another 10 or so seconds.
    There’s an approx 90 second video here of how the cycle goes before cutting if that helps https://streamable.com/ini1u9
    Any advice would be great, thanks!
    #493480
    if the wash pump is energising then could be capacitor
    if its not energising check for broken wires at the bottom of the door
