I have a Lamona 8606 integrated dishwasher. The display lights up and allows me to select programs but when I close the door to start the cycle nothing happens. No noise at all. So far I have followed the following steps in order to troubleshoot:
1 Turned on and off at the wall
2 Removed water and waste pipes to check for blockages. No apparent issues
3 Checked filters clear inside (drained any standing water with a sponge
4 Removed front panel and door switch. Tested switch with multimeter – current changes when button is pressed so seems to work as expected
5 Removed bottom panel – No leaks, everything looks intact
I’ve searched this and other forums and I can’t seem to find anyone with the same issue so any help appreciated. FYI – dishwasher has been used for almost 2 years
