Lamona (Beko?) Dishwasher LAM8601
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Lamona (Beko?) Dishwasher LAM8601
  • #91740
    WhiteVanMan1
    S/N – 13-514356-07
    I have two flashing LED’s. The 35 degree led and the 50 degree led are flashing together. Apart from that there is nothing happening at all. I’ve checked the obvious, ie the pump, water etc, but to no avail. I can’t find the possible fault code anywhere. Can anyone help please? Cheers in anticipation. Steve.
    #449104
    Seamy
    Re: Lamona (Beko?) Dishwasher LAM8601
    Hold down the start cancel button for 5 sec’s, this should clear setting if its stuck on programme.
    Problems that occur on them are loom breakages on the fine wires to NTC & water counter, door switch has the problem of being in closed position while door is open, this would prevent appliance from starting as door has not noticed its opened..
