Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › lamona (beko) HJA 8362
- This topic has 7 replies, 5 voices, and was last updated 13 years, 2 months ago by
sce.
January 16, 2013 at 1:13 pm #73573
sce
ParticipantHelp someone! Lamona badged up Beko hja8362. All progs lights are on and does nothing else in other words no go, nothing. Tried pressing prog and start buttons together and then switching m/ch on but still nothing. Took all wires off pcb to have a look and nothing looks iffy, reassembled and still the same. any ideas `cause the only thing I can think of is either this main board or the pro board have gone wrong. The door swt is ok. Ta
January 16, 2013 at 8:06 pm #388013Seamy
ParticipantRe: lamona (beko) HJA 8362
As with all Beko dishwashers, check the float switch for loose or burn’t connections. If its o.k then try a P.C.B they’re only about £20.
January 16, 2013 at 8:42 pm #388014AMS
Just changed a module on one of these today for that very fault. Worked a treat, and as Seamy says, remarkably cheap!
January 16, 2013 at 9:06 pm #388015sce
Thanks guys for the pointer. Will fit part and report back. Thanks too for the flood swt will double check when I get there.
January 21, 2013 at 6:41 pm #388016sce
As usual thanks for the great help. You were right guys.
January 21, 2013 at 7:13 pm #388017Seamy
sce wrote:As usual thanks for the great help. You were right guys.
Just to clarify for anyone else reading the post in future, right that it was float switch or right that it was P.C.B?
January 22, 2013 at 4:30 pm #388018iadom
ModeratorRe: lamona (beko) HJA 8362
sce, will you please read and respond to the PM’s I have sent to both you and your alter ego, andyjawa. A reply would be most welcome and the courteous thing to do. 😉
February 11, 2013 at 8:11 pm #388019keithwilliams
yes clarification would be helpful. however the one i went to today which i have decided needs a module would work if i disconnected the selector pcb wires and then reconnect while powered up. it would then allow selection and cancelling etc. the cycle would even work perfectly. but!! once poered off at on/off switch it was back to all lights on again.
maybe some electronics buff can deduce which main board component may be at fault.
k -
