lamona/beko hja8631 dishwasher
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries lamona/beko hja8631 dishwasher
  • #77045
    mikehha
    hi all. dose anybody know what or if the fault code is when the 35 and the 50 degree (2nd and 3rd ) buttons flash. and you can`t get it to do anything else.
    #400544
    Seamy
    Re: lamona/beko hja8631 dishwasher
    Hold in the reset button for at least 5 seconds, see if it clears itself.
    Possible that you have or because of poor installation that 2 buttons are pressed in when door is closed. I’ve had this kind of problem that a mounting screw on the brackets holding appliance in place are not in far enough & when door is closed buttons are pushed in by said screws.
    Something to check, when you check this will you let us know what the “buttons flashing” are.
    Do you mean the program selection button for & start buttons?
    May need a display card p.c.b replaced.
    #400545
    mikehha
    Just to update on this fault. I had to replace the button pcb and the control card aswell seems to have cured the problem.
