Hi there, hopefully someone can help me with this problem.
my Lamona built in dishwasher model Lam8601. I start any cycle, it fills for around 10 seconds, then stops dead!! Does absolutely nothing even if left.
I looked in the leakage tray underneath and there are no leaks. Water pressure is fine (off the mains) I can do a reset and it pumps away the water.
the fill level is only half way up the filter sump area not even up to the stainless tray.
any suggestions on what may be at fault?
thanks
