Lamona dishwasher leak
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Lamona dishwasher leak
  • #102855
    RyanHobby
    Hi all,
    sorry if it’s been asked before but I’m struggling. My lamona integrated washer keeps leaking into the reservoir at the bottom, obviously this sets the flood switch and E01 error then occurs.
    is this because my dishwasher won’t pump the water out? Is there too much water? How do I resolve the problem?
    I have checked the waste hose etc and all is clear and clean with no obvious signs of where water could come from.
    videos below
    https://youtube.com/shorts/DEfuh57yB2Q?si=z_Cx6KNDyouTj2NO
    https://youtube.com/shorts/_9u8-9lTsrs?si=j22016j80bXPQOgC
    thanks
    #490784
    difficult to see from the video but it seems to be coming from around the water softner
    had a few rust through the stailess tub round or under the nut securing the softner unit
    check when it leaks and see if the is water on top of the softner which then drips down
    you have the salt cap inside the machine and a big plastic bottle under the floor at that point. you need to look at the bottle and see if its wet on the top. you could remove the left side to see better
    matrixresonator
    I’ve had a couple of those machines leak from where the air break connects to the salt tank, replacing the O rings has fixed most of them.
