Lamona Dishwasher Program freeze an lights
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Lamona Dishwasher Program freeze an lights
  • #82028
    AlanC10
    Hi All,
    firstly I couldn’t select any programs, it was stuck on one but still worked, now the display is stuck on all the time (all lights on) and reset has no affect. Please can you advise what spares I might need. Looking at the forum it suggests its the display board for the lights on issue but don’t know about the program stuck problem. In addition, if thats not enough the door just drops to the floor, the wire inside I assume has snapped. Is this mechanism in the door or side panel. Is this is an easy job to fix, please advise parts . I’m pretty competent at most things
    thank you
    #418502
    Re: Lamona Dishwasher Program freeze an lights
    as you can imagine without more info its hard to guess a problem
    Lamona is the brandname used by Howden joinery. they usually use Beko machines but not always
    the door droping will be the springs or wires. pull out dishwasher and take sides off to see whats gone
    as for the other problem.
    Does the door feel like it opening and closing properly (with a click)
    if not door switch may be in the closed position so buttons may not work
    AlanC10
    Hi Dave,
    thanks for info, it’s a HJA8630, we’ve had it about 4 yrs, to be honest we’ve had no problems at all until recently. First it stuck on one program wash at a higher temp, the select button can be pressed but the icon on the display wont move. But it still worked fine. Then today all the lights came on and even with reset won’t go out ( obviously until turned off)
    I’ve checked the door and it does click shut so that seems to be ok
    #418504
    AlanC10
    i’ve opened up the top half which houses the PCB modules. My display module has the coding 174962, the PCB on the spares/shop looks very different, unless this is housed within the plastic moulded outer with the clipped wire harness connections, is this correct.
    #418505
    AlanC10
    I’ve changed the display board and all works fine. The most annoying thing is trying to find bolts the right length for the panel to re fix on. Heads worn originally and stripped in the panel. One of those quite easy to do jobs once you know, type of jobs.
