The main oven does not heat up when the fan is on. Yesterday when the oven was on something tripped the circuit breaker. Did not notice anything wrong as it was near the end of the cooking time. Now when the oven is on, top & bottom elements get hot & when in grill mode both inner & outer elements get hot but when the fan is switched on none of the elements get hot. Can you help please.
Re: Lamona double oven, main oven not heating up when fan on
Yes, there is, I’ve just removed the fan cover. Do I have to remove the oven to get at the screws that secure the element? Are these ovens just pushed in or normally secured at some point? Model is LAM4600
sjw26 wrote:Yes, there is, I’ve just removed the fan cover. Do I have to remove the oven to get at the screws that secure the element? Are these ovens just pushed in or normally secured at some point? Model is LAM4600
the element has 2 screws holding it in from the rear
