My Lamona Fridge freezer model number hja6855et has starting freezing my food and
ice is building on the back wall of fridge..I believe it may be the thermostat ..I have removed
the temp control cover and cannot find this part anywhere its marked on the pcb penta13-10 4360630285 any advise is very welcome
Its electronically controlled so no thermostat as in the traditional sense so it if its building up thick with ice at the back it could be the NTC but its foamed into the insulation or most likely in my view a system fault IE- lack of gas/in restriction/compressor failing
