Lamona HJA 8362 – not controlling heater?
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Lamona HJA 8362 – not controlling heater?
  • #89906
    Fulcrum
    Came across this site when googling for information to help – it seems a great resource so I’ve signed-up. Here’s the problem…
    Model: Lamona HJA 8362 compact fully integrated dishwasher.
    Serial: 11-505439-07
    Type: Art 9 Class 1
    Other: 78105 R-59
    This Lamona seems to be a re-badged Beko or similar.
    Ran fine for 3 years.
    Symptoms:
    1. On the “Pre-wash No Heat” program the heater is on when it seems it should never be judging by the programs name.
    2. On our normal “Economy 50-degree” cycle; during the cycle when water is drained, the next inlet of cold water makes the ‘walls’ get sucked in and there’s a loud whoosh of air being drawn in as the hot air within gets suddenly cooled.
    Searched, read and concluded the NTC thermistor / sensor needed replacing. Replaced it, but the Pre-wash cycle still runs with heat.
    #442972
    Re: Lamona HJA 8362 – not controlling heater?
    the heater is switched on by a relay on the board if that relay is short circuit it would cause a problem like this
    Fulcrum
    Cheers Dave – I should’ve guessed there’d be a relay involved for high wattage like heating – I’ll have to see if it’s a readily replaceable item.
    #442974
    Simon46
    Replace pcb.
    #442975
    Fulcrum
    Thanks Simon46 – I’d found on another thread that the relay was on the PCB and ordered a PCB thru this site – tho’ this site goes to great lengths to dissuade people from buying PCBs (‘cos apparently 70{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of those ordered aren’t really the solution) – so it’s great to have your reassurance that a PCB is appropriate in this case.
    #442976
    Fulcrum
    Update:
    Replaced main PCB.
    Success – thanks to forum, Dave & Simon.
    Cold cycle runs cold, hot cycle runs hot (but not too hot anymore).
