Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › LAMONA HJA 8552 won’t finish cycle-delay+start button flash
- This topic has 6 replies, 4 voices, and was last updated 13 years, 1 month ago by
jojomonty.
February 17, 2013 at 10:19 am #74176
jojomonty
ParticipantI have an integrated Lamona HJA8552 Washing machine from Howdens which won’t complete a full cycle. After filling with water, and the drum starting to turn, it cuts out and both the play button and the delay button start flashing. They flash 5 times in a 15 second timescale.
The machine drains ok-we have checked the filter and pump for debris. It seems to advance further when there are no clothes in the machine, stopping at the spin stage.
Any ideas? I can’t seem to find out what the fault code might be.
Many thanks in advance.
February 17, 2013 at 10:25 am #390354helo_75
ParticipantRe: LAMONA HJA 8552 won’t finish cycle-delay+start button fl
thats a hoover nextra machine
error 5 is the ntc not sensing
its the little temperature sensor on the back of the drum, just over the heater
unplug it and try the wires on it, they may be broken on the connector
if its not that it will require replacing
quite common
February 17, 2013 at 9:20 pm #390355jojomonty
We pulled out the temp sensor and checked connections and they seemed ok. It was covered in gunk/slime on the inside! Should it do this??
February 18, 2013 at 8:14 am #390356Martin
Yes they get pretty yucky after a while but wouldn’t usually cause a problem. What you really need to do is to REPLACE that sensor and that should solve the problem. 😀
February 19, 2013 at 10:27 pm #390357jojomonty
Just wanted to say a big thank you! Sensor replaced and now all working again for £20.
Thanks again!
September 19, 2013 at 5:17 pm #390358dogstar
Had the same problem.Did the same thing changed the senser.But the lights have gone out but the other symptoms are still happening.No spin or advance.Any thought on brushes’
September 25, 2013 at 11:16 am #390359dogstar
Participantno answers
Hi there I have a Lamona HJA8552.I looked up on sight and it advisd it could be error 3.There’s no blockage at the pump or the other hoses going to it.The pressure pump is clicking I did blow back up the tube and it clicks.I’ve changed the pump for new.It still comes up with same error. start and advance lights come on 3times in 15second intervals.It will not finish any was programme or spin. Thanks
