Lamona HJA 8553 not draining
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Lamona HJA 8553 not draining
  • #80164
    hilsden
    Hi, can anyone help? My Lamona Washing Machine HJA8553 is not draining the water away, the machine still washes and spins. It stops near the end of the cycle and the 90 minute and the cold wash button flash. What could the problem be?
    #411937
    Re: Lamona HJA 8553 not draining
    Have you checked the filter?
    hilsden
    Where would i find the filter? Do I have to pull the whole machine out?
    #411939
    It should be behind the plinth at the bottom from memory so you shouldn’t need to pull it out.
    hilsden
    I have pulled the washing machine out, looked all around it and taken the top and back panel off and I am still unable to find the filter. Is it possible that it hasn’t got a filter?
    J
    #411941
    Andy jones
    The pump is at the back on the right hand side. ( as you look from the back ). My guess would be pump jammed. Easy enough to take off and look, drain all water out 1st
    #411942
    hilsden
    Many thanks for all your excellent advice. I spent a lot of time and effort in locating the problem and eventually found the fault.
    There was no filter on this model but after taking off the pump I discovered one of my daughters hair clips inside jamming the pump.
    Thanks for all your help.
    J
