I have a Lamona HJA 8630 Dishwasher which stops before emptying. The bleeper sounds as though the program has finished but the water has not drained.
I can then drain the water by swithing off,holding down the keys and switching back on so I don’t think its the pump. I’ve cleaned the filters but atill have the problem.
The dishwasher is actually a Beko made machine and I can’t fathom any reason for it doing that from a quick look but maybe one of the guys will have seen this behaviour before.
Is the water heating though as, on those dishwashers the heating element is a fairly common failure and it’s this one:
Pump could be faulty i’ve had to change a few for this problem, assuming you have checked the filters it is more likely though to be a blockage in the drain hose or the pipework its going into.
If you put drain hose into basin/bucket etc, run it that way & see if it drains correctly.
Thanks Seamy – my husband finally got round to removing the plinths etc to get the dishwasher out and you are rught – the outlet hose had become distorted. Thanks again.
